Skipping problem...need help
Old Dec 26, 2005 | 08:45 PM
ROL WTME's Avatar
I installed a set of Hooker long-tubes the other day along with a cut-out and a flowmaster cat-back. When I took the car for a spin after it was all installed, when I go to kick it, it skips real bad and has a lot of hesitation and it wont just take off. I checked all the sensors and nothing is bent and all of them are fine. Can someone please tell me what is wrong? thanks
Old Dec 26, 2005 | 09:02 PM
2000GTP's Avatar
Re: Skipping problem...need help
Did you also recheck your spark plug wiring? It is easy to mix them up sometimes and plug them into the wrong locations.
Old Dec 26, 2005 | 09:04 PM
ROL WTME's Avatar
I didnt check those-thanks
Old Dec 26, 2005 | 09:34 PM
OBE1 95Z28's Avatar
Scan the car and look at your knock readings; headers can generate false knock causing timing to be pulled from the engine resulting in hesitation.
marlar98
Sep 19, 2015 07:53 AM
jmadoll
Jun 10, 2015 04:41 PM
QUASARBLUEZ28
Sep 10, 2002 05:50 PM
91Firecrow305TBI
Jul 16, 2002 01:46 PM
91Firecrow305TBI
Advanced Tech
