Single Plane Guys - PCV Question
CMoney
12-23-2005, 09:01 PM
For the guys running single plane setups, what are you doing for crankcase ventillation? Adapting one to work? Running a vacuum pump (viable on a street car?)? Just looking for some input. Thanks.
SStrokerAce
12-23-2005, 09:28 PM
Last one I setup used LT4 valvecovers and a line from the intake plenum.
Bret
atljar
12-23-2005, 10:06 PM
I ran a breather in one valve cover, and a push in style PCV valve in the other. From the PCV ran a vacuum line to the intake.
I have since switched to just two breathers, i couldnt get the PCV to stop sucking oil.
CMoney
12-23-2005, 11:38 PM
How long have you been running only breathers? I was leaning that way, but all the research I've done says that the PCV plays a big role in keeping the oil clean during light throttle conditions.
How much oil was your valve cover PCV valve sucking? I wonder if a small oil separator plumbed inline would work...
atljar
12-24-2005, 12:29 AM
A few thousand miles. I change the oil under 3k miles with synthetic so i never really worried about long term effects.
I also ran without any evac system... bad idea. I had tons of moisure build up in the valve covers.
As for how much sucking? Not totally sure, but enough to coat the intake. Im sure a seperator or catch can would work, i just never cared to try and find out. I eventually planned to run the stock AIR pump as an ultra cheap vacuum pump, but never got around to that either.
FASTFATBOY
12-24-2005, 08:33 AM
Was the valvecover baffled where the pcv was pushed in? If not, it needs to be to stop sucking oil.
David
atljar
12-24-2005, 04:40 PM
It was the stock baffle on the passenger side
SStrokerAce
06-20-2006, 10:09 PM
Add on to this post. I have a distributor hole plug that has a provision for a PCV that is really trick. Thanks to OldSStroker.
Bret
bdc95ta
06-21-2006, 07:42 AM
Bret
That sounds cool do u have any pic's Bret?
-b
SStrokerAce
06-21-2006, 12:47 PM
Not yet, but I can take one today. E-mail me about it.
Bret
Black95Form
06-22-2006, 06:26 PM
Love to see it.
