wrd1972
12-22-2005, 10:15 PM
Does anyone make sub-frame connectors that fit convertibles?
Vert sub-frame connectorswrd1972 12-22-2005, 10:15 PM Does anyone make sub-frame connectors that fit convertibles? CheshireCat 12-23-2005, 06:18 AM If you are looking for subframe connectors for a 4th gen convertible, then Yes. BMR makes a weld on tubular with extra weld points especially for the convertible... Runs $179 I think... Kenny Brown makes the DDouble Diamond for convertibles. They are also weld on and run $279... SLP made a bolt on that was similar in design to the BMR, but I don't think they are available anymore... They were $350 and probably aren't the best choice even if you can find them... Good luck, Steve wrd1972 12-23-2005, 07:59 AM Thanks, I will look and the BMR's. | ||
