ported heads
Old Dec 22, 2005 | 12:34 PM
brady014's Avatar
ported heads
how much HP gain could i expect from having my heads ported and polished? im running a 98 3.8 w/ a magnaflow muffler..
Old Dec 22, 2005 | 11:00 PM
AlfredB18's Avatar
Re: ported heads
It depends how crummy the ports are on a 3.8L. On a 3.4L, for example, I'd expect a dozen(ish), since the flow is so bad, but the cam and valve size are pretty good.
Conversely, some engines have heads that are pretty well done up from the factory.
Old Dec 22, 2005 | 11:08 PM
MyShibbyZ28's Avatar
Re: ported heads
Agreed. The most I have heard/seen with just heads is barely even 20 hp.
Old Dec 23, 2005 | 06:26 PM
PaganEgyptian's Avatar
Re: ported heads
I wouldnt bother unless you will be running forced induction or Nitrous. Porting the Heads will give better flow, but it will also lower your Compression Ratio.If you port them you may see around 12-15HP for a 3 angle cut. I would advise porting the Throttle Body and do a recalibration which will give you almost that much combined with a K&N. If you port it, make sure you replace the MAF screen or you will be kicking MAF codes non stop.-Tim
Old Dec 23, 2005 | 07:22 PM
34v6needhelp's Avatar
Re: ported heads
Good tip...thanks!
Old Dec 24, 2005 | 03:24 PM
1fastnav6's Avatar
Re: ported heads
You dont needs heads until after you do a cam.
www.abbottracingheads.com
Go to them for your needs.
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Wilson
Jul 21, 2002 05:08 PM
