ECM Codes decode
ringo234
12-21-2005, 08:12 PM
OK I figured out how to jump the connector. It 12,12,12 then 36,36,36, and finally 45,45,45 then began to repeat. I looked up the codes in a Haynes manual.
12 = ???
36 = MAF grounding problem
45 = replace O2 sensor - exhaust too rich.
I couldn't find a code for 12. Any Help would be appreciated.
Wacky Tower
12-21-2005, 08:31 PM
code 12 is basically letting you know that the ecm is functioning. If you had no other codes it would only flash 12
ringo234
12-21-2005, 08:44 PM
thanks
Pneumatic_Tire
12-21-2005, 09:42 PM
Code 12 is basically just a code saying there is no distributor signal. Normal code that all flash first.
nj85z28
12-22-2005, 06:44 PM
code 12 actually means Diagnostic Mode
