LarrieuY2KSS
12-21-2005, 02:37 PM
I am interested in lowering my car with a set of the eibach sport line springs. My SS has 61,000 miles are the shocks still good or would it be wise choice to upgrade them will I'm under there getting dirty:confused: ? Also what would be a good shock and strut set up with the eibachs
TobyZ28
12-21-2005, 02:46 PM
Lots of people would recommend you get new shocks even if your car is fresh off the factory floor :)
Might as well do them at the same time if your changing the springs too.
Camaro_Maniac63
12-21-2005, 03:11 PM
Welcome to the board. First off, if I were to recommend you lowering springs, Eibach sportlines wouldn't be the ones. Those particular springs are great for looks, but bad for handling since they are too soft for how much they lower and will cause you to ride your bumpstops too often. If you want to lower that much, look into H&R springs or LG Motorsports G2 springs. If you can get away with approximately 1" lowering, I think the Hotchkis springs are a good choice. In either case, you absolutely need to change your shocks. Look into either revalved Bilsteins or Koni single-adjustables. Good luck.
LarrieuY2KSS
12-21-2005, 03:17 PM
Hey thanks a lot you guys, hope to have my springs soon will post some pics once it is done
Greed4Speed
12-21-2005, 06:06 PM
Yup. Eibachs tend to ride the bump stops and settle in the rear, if you like the look of the rear being lower.
TazmanSS
12-21-2005, 07:00 PM
What about bmr progressive rate springs?
