ddj19852003
12-20-2005, 09:53 AM
Im thinking of buying some intrax springs, they are for the 98-02 cars will these work on my lowly Lt1 or are these springs soley for the ls1 cars?
Ls1 and Lt1 lowering spring differencesddj19852003 12-20-2005, 09:53 AM Im thinking of buying some intrax springs, they are for the 98-02 cars will these work on my lowly Lt1 or are these springs soley for the ls1 cars? Camaro_Maniac63 12-20-2005, 03:39 PM The spring rates are probably different for LS1 cars compared to LT1 ones. You should call them and ask them, that is what they are there for. Good luck. convertz 12-21-2005, 12:42 AM The front end weight of an LS1 car is less because of the all aluminum motor so the springs can be lighter I would think. I believe they all fit though because BMR springs are advertised as fitting 93-2002 for one set of springs. just my thoughts tho Camaro_Maniac63 12-21-2005, 10:33 AM The front end weight of an LS1 car is less because of the all aluminum motor so the springs can be lighter I would think. I believe they all fit though because BMR springs are advertised as fitting 93-2002 for one set of springs. just my thoughts tho Not "lighter", but "less stiff". Springs are mainly characterized via their stiffness; the equation is F=-kx, where "k" is the spring rate expressed in force/length. Anyways, enough physics :) convertz 12-22-2005, 07:20 PM Thats what I meant. The stuffness of the whole system is characterised as F=kx+cx(dot)+mx(double dot) With m the mass of the system and c the damping coefficient Im a 3/4 mechanical engineering student;) :irk: Camaro_Maniac63 12-24-2005, 03:08 PM Thats what I meant. The stuffness of the whole system is characterised as F=kx+cx(dot)+mx(double dot) With m the mass of the system and c the damping coefficient Im a 3/4 mechanical engineering student;) :irk: Just messing with you boss :) I am engineer myself and sometimes when someone posts something that may be misleading, I feel the need to correct it :D I later looked at your sig and realized you probably knew better than your initial post :thumb: | ||
