compression
billyburnout
12-16-2005, 11:57 PM
What is the highest compression that anyone is running on pump gas with aluminium heads. Im taking out my 9.5 slugs and want to go with 11.0, but I hear mixed opinions about what will work.
bdc95ta
12-17-2005, 12:37 AM
their's a guy here in h-town running like 12.3 Static
-brandon
jimbob65
12-17-2005, 02:35 AM
I'll answer this before it gets moved....
I run 12.48 to 1...It's not the SCR that gets ya, it's the DCR....Mine is only 8.77....Many here have run 9 to 1 but you have to get everything right on for it...Heck, mine was hard enough to tune...and goes into hard detonation a lot easier than before...After lots of tuning it's all good....:D
1racerdude
12-17-2005, 04:05 AM
Are ya running an LT1 with reverse flow cooling?
Jimbob
Get ya some good cooling and it will do better. There are people running 9.6 an pump gas but I will stay at 9.1 'cause that's the way it came out. My static is 13/1.
jimbob65
12-17-2005, 10:13 AM
Jimbob
Well, if I used my theoretical .006 ABDC (using intake duration and ICL), I would be right at 9.18 to 1 (74.5*ABDC). I checked my actual ABDC and came up with 79*. Several times...on two different lobes....Makes sense, because I got a base duration of 295 instead of 289 listed on lobe chart :( The exhaust lobes were right on the money so, I did have two control lobes....Moral of the story.....our DCR's may not be as high as we think...
billyburnout
12-17-2005, 12:51 PM
Jimbob
I'm running this in my 540.
1racerdude
12-17-2005, 01:53 PM
It is the same rule of thumb.
respectirocz
12-17-2005, 10:00 PM
i'm guessing scr and dcr stand for
static compression ratio and dynamic compression ratio
and i'm guessing static means the compression ratio calculated from total combustion chamber volume at bottom dead center to total combustion chamber volume at top dead center
what is dcr? and how is it calculated?
383Z4ME
12-19-2005, 12:53 PM
http://members.uia.net/pkelley2/DynamicCR.html
Good write-up!
1racerdude
12-19-2005, 02:22 PM
If it isn't reverse flow cooled ya better stick to 8.5DCR or ya may have to run fuel in it.
SStrokerAce
12-19-2005, 03:38 PM
Problem is how you get there... usually high compression big blocks take some dome to get, and that can cause issues on a pump gas high DCR motor.
The other side of this is how much VE can you make, the more you make the less compression you can run. Hell the less compression you need, everyone seems to think a Pro Stock motor is running some crazy SCR, but it's really around 15:1.
Bret
respectirocz
12-19-2005, 03:50 PM
Good write-up!
:thumb:
1racerdude
12-19-2005, 03:52 PM
If the dome is built right and has a fire slot it will be fine. Shouldn't take THAT big of a dome to get a 8.5DCR with a 75*IVC. Ya can always buy a small CC chamber head.
Hey: 15 to 1 will get it done...
