how do i change the front turn signals
Old Dec 13, 2005 | 01:28 PM
RedDrayken's Avatar
Hey, my front turn signal bulbs went out and i need to replace them to get my car inspected, when i went to change them i couldnt figure out how to get into it. Its a 97' Z28.
Old Dec 13, 2005 | 02:15 PM
94Z28/SSw's Avatar
Re: how do i change the front turn signals
You have to go up underneath the front end, right in front of the left or right fender, which ever side you need to replace. You will need to take out about 4 bolts, pull the plastic down, and reach up in there and take the lamp out. The more bolts you undue to remove the plastic, the more room you will have to work with.
Old Dec 13, 2005 | 02:17 PM
ReNxWar's Avatar
Just like he said, except lemmie put some emphasis on being careful. The plastic is very thin and will strip out easily.. I have a few stripped holes thanks to a clear corner install.
Old Dec 13, 2005 | 03:35 PM
2000GTP's Avatar
Also, another tip would be to spray down those bolts with some rust penetrant. Like stated above, the plastic is brittle and once those bolts rust in there, both the plastic and the bolts tend to break. I learned that the hard way..
Old Dec 13, 2005 | 03:58 PM
RedDrayken's Avatar
thanks guys. i can blink now
F'n1996Z28SS
Aug 23, 2023 11:19 PM
stangspank
Nov 13, 2015 01:02 PM
Jul 4, 2005 05:00 PM
Ryabut98
Sep 3, 2002 11:45 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
