left turn signal
Randy1994
12-11-2005, 06:46 PM
i have a problem with my left turn signal. it stays solid when i turn it on. the right side works great. i checked the grounds. installed new flashers. anyone got any sugestions?
lil_mikey69
12-11-2005, 07:12 PM
And you are sure that one of the turn signal bulbs is not burned out?
Randy1994
12-11-2005, 07:16 PM
yes both bulds r good and grounds r good
SFB767
Definitely check the bulb.
When my turn signal was solid my bulb was burned out. I replaced it and everything worked fine again.
Randy1994
12-11-2005, 07:30 PM
i just went out and checked bulbs again. bulbs r good and it started working i will be replaceing the bulds and possible changeing the sockets. thanks for your help
