th400 w/ Turbocharger
Old Dec 10, 2005 | 01:34 PM
ehacker01's Avatar
I got a good deal on a street/strip th400 that I would like to take advantage of. The only problem is that it is a manual/automatic, I was told on the 400 if you have a turbocharger you need to use a full manual because they use vacuum to know when to shift.
If I just drive "normal" it should shift fine since there'll be no boost. With a manual/automatic shift kit I could still shift it under boost right? I would just have to make sure and shift it and not forget that it won't shift on its own. Am I correct on this? I was also thinking, couldn't I just use a check valve when manually shifting it so the tranny just thinks there is 0 vacuum. Whenever you are @ WOT you are @ 0 vacuum anyway.
Old Dec 12, 2005 | 07:21 PM
cablebandit's Avatar
Re: th400 w/ Turbocharger
i have the same setup...vacuum hose with a checkvalve...it works fine. I dunno where these myths come from...mine is forward vb...manual/automatic just like yours
Old Dec 12, 2005 | 07:26 PM
ehacker01's Avatar
Are you just using the check valve or do you also have a "vent" in between it and the modulator? I was thinking just using a .027 welding tip to bleed off vacuum while that check valve is closed.
Old Dec 12, 2005 | 07:37 PM
just a check valve left over from the vac. mod kit my 4l60e had......it is closed under vacuum and opens under boost
RUENUF
Mar 13, 2016 03:37 PM
james007moore
Jan 1, 2016 01:14 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
detroitmuscle
Jul 31, 2015 04:21 AM
cmsmith
Apr 11, 2015 09:37 PM
