I might be joining you guys next season!!!
Old Dec 9, 2005 | 11:25 PM
speedyjr's Avatar
I will hopefuly have my car done by mid season next year. I just picked up a garrett 91mm turbo, it should be here mid next week. Then within the next couple months I'm going to start on the headers and hot side. I will update with pictures as I make progress. I have had enough seasons of nitrous, now time to try the FI. BTW, this will be a blow through carb setup on a ~383 lt1. I'm only going to shoot for ~9.50's this upcomming season while I finish the chassis and odds and ends. I do have a couple questions to start off with though. Who make a good 1/2" header flange? Has anyone succesfuly used a set of off the shelf shorties like the mustang boys do? What size wastegate should I be using with a turbo that big?
Old Dec 11, 2005 | 03:52 AM
speedyjr's Avatar
Re: I might be joining you guys next season!!!
ttt
Old Dec 13, 2005 | 06:27 PM
speedyjr's Avatar
I got the turbo today. It has a 1.32 a/r so I'm not sure if that housing is going to work for me. It will be a 383 and not worried about street use. Do you guys think I will be able to spool it?
Old Dec 14, 2005 | 08:11 AM
RealQuick's Avatar
Seems large to me...maybe to big. As long as you can build boost at the line...then it should be good. Be prepared to have peak tq/boost above 6k rpm though.
Old Dec 14, 2005 | 08:34 AM
breakmyfootoff's Avatar
That is way huge, you probably wont be able to get it spooled until your way down the track. Search for posts by wingnut, he had a 91 mm with I think a 1.00 ar housing on his 383 and was having trouble getting it to spool.
Old Dec 14, 2005 | 08:40 AM
Here is an what he said about the 91 mm with a 1.00 ar.
"If my converter was not so loose, lag would be unbarable. However, with a 4000 rpm stall, you get off of the line and watch the bike go ahead of you for about a sec then everything gets blury and you just hang on. A little soft on takeoff. I thought about using NOS and have my DFI 7 turn it on until positive map pressure is present then all turbo after that.
I changed and went with a tb-91 big frame turbo and now have the 1.00 a/r turbine housing. I am going to order a .96 and try that too - housings are cheep!"
Old Dec 14, 2005 | 10:41 AM
speedyjr's Avatar
Cool. I will give the housing a try and if it doesn't work I will pick up a new one. I plan on spinning the motor to ~7600 leaving off a trans brake. Do you think the 1.00 would start to choke in the higher rpms? Thanks for the help guys. I also think I'm stuck buying a 60mm wastegate which sucks cause they are expensive as heck.
Old Dec 14, 2005 | 10:53 AM
95Bird's Avatar
Looks like you and I are going to be doing the same kind of build. I'm going to run a 383 with 91MM with a 1.0 AR housing. I don't think a small cube 383 even at 9000 will choke these turbos. If it does..which I highly doubt I have a 1.32 sitting here looking at me I can go to. I plan on going alittle higher in the rpm range than you do and I'm going to "try" it on the 6 speed at first. Hopefully with a 2 step and the boost builder part of my DFI gen 7 I can leave halfway descent. What can I say..I'm a glutten for punishment.
Old Dec 14, 2005 | 11:16 AM
RealQuick's Avatar
Can you run twin 38 or 40mm gates instead of a single 60mm? Its probably cheaper.
Old Dec 14, 2005 | 11:27 AM
speedyjr's Avatar
Yes, I probralby can run 2 wastegates. How much is a new housing so I can have both the 1.00 and the 1.32 sitting around? I guess I could just call precision and find out.
Old Dec 15, 2005 | 01:04 AM
I bet it would be pretty hard to outgrow that turbo with any size small block. Even though wingnut mentioned that it seemed like a soft launch, that would be desirable if you were going to run in a street tire class. However it wouldn't be much fun for a car that you are going to drive on a regular basis. That setup would be perfect if drag racing is your primary goal, however if you want to build something like an all around performance car a smaller turbo would be better for you. It all depends on your personal goals for the car. I try to imagine what Enzo Ferrari would do if he went broke and the only car he could afford was a Camaro. Basically I want an exotic supercar, but since they don't pay firefighters very much I'll have to get as close as I can with my Camaro.
Old Dec 15, 2005 | 10:38 AM
speedyjr's Avatar
Yea, it's main purpose in life is to go down the track. I might drive it for the once a month cruise nite and that's about it. I've got some pics of the turbo I will try and get uploaded today. I orderd most of the flanges and tubing so I can start on the headers when that gets here. Does anyone have a good way to make the round pipe d-shaped to fit the header flange?
mr28
Apr 20, 2016 05:44 PM
cmyname1
Feb 16, 2015 08:33 PM
192cobra
Jan 26, 2015 12:12 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
Red97LT1
Aug 7, 2002 05:45 PM
