1996 Camaro Z28
Old Dec 4, 2005 | 04:22 PM
mustangmuncher's Avatar
1996 Camaro Z28
As title says
103k miles, runs great.
Mods in sig.
Pics are here http://www.cardomain.com/ride/678908/2
The site says I have a loudmouth, which I have replaced with the Hooker cat-back just recently.
Transmission rebuilt in last 2000 miles. Shift kit was installed, as well as transmission cooler.
I removed the rear seats, but still have them. Will go with the wheels, they fit great, no rubbing, just had to remove the bump stops. Also just replaced the rearend fluid with Lucas and the GM additive. Oil changed every 2000 or less miles since I have owned it with Castrol Syntec 0w-30 has seen snow a little bit.
Front bumper needs replaced, chip behind drivers door, rear bumper has spider cracking/scratches. Before I put on the ZR1 wheels the driver front centercap popped off putting a large scratch on the drivers door near the bottom. Interior is cloth, never smoked in/eaten in since I have owned it.
Parts that will come with it include: Pacesetter LT's/Y-pipe, the collecters need fixed. Cylinder heads and intake off a 93, the loudmouth. Passenger window motoring going dead, will be replaced soon, only time the t-tops leak, is if the water is being sprayed at a certain angle with high pressure, no dripping on you while driving.
Reason for selling is I will be leaving for the military soon, and will have no need for it. Would prefer local. N.E. Ohio
Thanks,
Eric
Old Dec 4, 2005 | 04:49 PM
projectcam's Avatar
Re: 1996 Camaro Z28
How much. Pm me please
Old Dec 6, 2005 | 11:51 AM
Re: 1996 Camaro Z28
ttt
Old Dec 9, 2005 | 06:36 PM
Re: 1996 Camaro Z28
ttt
Old Dec 9, 2005 | 09:09 PM
KeeblerElfZ28's Avatar
Re: 1996 Camaro Z28
you by any chance selling the rims/tires seperate from the car?
Let me know.
Old Dec 9, 2005 | 10:04 PM
Re: 1996 Camaro Z28
I might be, someone is considering buying the car without the wheels. I will let you know though.
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
siguy
Nov 27, 2014 10:07 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
