choosing injectors, suggestions?
blown94
12-04-2005, 11:00 AM
Got an LT1 thats got a 220/230 114lsa, full bolt ons including some LE2 equivalent ported LT1 heads. Going to run a powerdyne, which I already own, at about 6-7 psi with an alky injection kit, no intercooler. What size injectors am I going to need?
SiCk PuPpY
12-04-2005, 11:54 AM
I have a similar set up; Bryan (PCMforLess) recommended 42 lb SVO injectors for my application. You can get 'em new on EBay for about $250 shipped. They are supposedly good to about 600 hp. Here's a link to the calculations page:
http://www.camaroz28.com/calcs/index.shtml
blown94
12-04-2005, 08:09 PM
yeah i tried that last time and got an error message. Wasnt sure if it was my fault or what. How do you get V.E.? And since I dont have a dyno chart, how do ya know where your max torque is? Maybe i missed something, ill try again.
EDS Z28
12-06-2005, 10:46 PM
I just use the basic well known formula:
Injector size = (HP X BSFC) / (8 X duty cycle)
For a blower car, the BSFC is supposed to be about 0.55 to 0.60.
So, assuming 600 HP, a BSFC of 0.55, and an 80% duty cycle:
Injector size = 51.5 lbs/hr
You can increase the power potential of an injector by increasing the fuel pressure.
You are not supposed to run an injector over 80% duty cycle or it could overheat and fail.
blown94
12-18-2005, 02:30 PM
Thanks a lot for that info, looks like 42 lb'rs should work just great and no risk of overworking them. Im assuming I am going to need a better fuel pump to run these though. Is there a pro/con to adding an inline pump to installing a better unit in the tank and tossing the stock'r or what?
97WS6SCharged
12-19-2005, 10:14 PM
Yeah, the inline pumps are noisy and they're only good at increasing pressure, not volume.
snorkelface
01-10-2006, 02:39 PM
I'm assuming that the HP variable should be based upon flywheel power, correct? Also, would it be better to figure the duty cycle at 75% or so as to be safe?
97WS6SCharged
01-11-2006, 10:51 AM
Yes, flywheel hp. 80% is the safe standard usually. :)
