Quick question about 9" moser set-up 4 my 94
Old Nov 29, 2005 | 08:47 AM
detroit1994z28's Avatar
Okay heres the deal. I'm buying a Moser 9 for a 93-02 Fbody The guy said it's for a 4 channel car with TCS and but he has the ABS sensors installed as well as ls1 brake plates and calipers,He said tis can be used on a car Without Traction control without any problem. Has a 3.50 rear gear, 35 spline axles and Posi unit. Moser Axles. Yoke is for a stock Driveshaft. Given that my car is a 94 with a 3channel abs set-up. Will this rearend work perfectly. Since all the brake plate and calipers are allready on set-up and abs sensors installed. - Let me know - ----Will I need to modfly anything or remove my a.b.s. Let me know asap
Old Nov 29, 2005 | 02:47 PM
1SlowFormula's Avatar
Re: Quick question about 9" moser set-up 4 my 94
I am pretty sure you will not be able to set your 3 channel ABS up to a 4 channel system and have it read/work correctly.. You may think about converting it to a 3 channel or getting rid of your ABS, I guess this all depends on the price your are getting the rear from and what you are going to be using the car for...
Old Nov 29, 2005 | 04:58 PM
Thanks buddy. Basically I wanted to know if this rearend will still work if I removed the abs. Which I plan to do anyways - thanks again - Mike
Old Nov 30, 2005 | 07:59 AM
Yeah if you plan to remove it, then the rear will definitly work... Like I said above though your ABS will not, but that has no interuption to the way the rear works...
Pull your ABS stuff and be happy your getting good rear under there...
Old Nov 30, 2005 | 01:34 PM
Yeah I really dont need ABS anyways. It's not like I use the car everyday. It's just a weekend summer time car. I'm just sick of never getting any traction. Atleast now I can run slicks.I cannot wait to launch the car at higher rpm without worrying about the rearend. - Thanks for the help again - Mike
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
ddr698
Jan 9, 2015 10:05 AM
kev93z28
Aug 19, 2002 12:48 AM
