Head Studs
Kevin Blown 95 TA
11-28-2005, 11:15 PM
Can anybody tell me if it is possible to get the heads off a studded block while it's still in the car. Mine is a 95 TA. Thanks. :D
Lonnie Pavtis
11-28-2005, 11:26 PM
Yes,
They will come right off with the studs in the block.
Kevin Blown 95 TA
11-29-2005, 07:04 AM
Thanksfor the quick reply!!!
Camaro_SS/R
12-01-2005, 02:23 AM
With the new studs you can also pull the studs off with an Allen wrench. Then the heads can come off without any clearance issues.
Kevin Blown 95 TA
12-01-2005, 11:04 AM
Hugh, are those ARP studs?
Camaro_SS/R
12-01-2005, 12:13 PM
Yup. It should have a hole on top of the stud for an allen wrench to go in.
Always always always put the proper thread sealant for the ARP head studs!! :)
cheers
--Hugh
Kevin Blown 95 TA
12-01-2005, 02:04 PM
Thanks again - that's a good improvement. I have the ARP thread sealer.
I always have a problem of whose torque specs to use. There's GM, ARP, AFR, & sometimes gasket maker. What does everybody else do? I'm going with the Cometic gaskets this time.
