Roadart
11-24-2005, 12:16 AM
Happy Holidays everyone,
Here's a link to a few pics, more to be added soon;
http://www.PictureTrail.com/gid8816787
I have also changed my asking price to $7200 obo, any reasonable offer accepted
I am looking to sale my 93 Z28 Camaro, its had a problem recently that I can’t seem remedy. I have already spent a great deal of money on this car and its come to the point where I need to get something with better gas mileage and that has a warranty.
I am not looking to part the car because I don't have the time or space to part it out (even though I know I could probably make more money)
I am not sure what I can ask and have people actually respond, so if anyone could give me feed back on how much I should expect to get I would greatly appreciate it. I am thinking that $8500 for the car is reasonable, Or best offer of course.
Below is a the list of mods and upgrades;
93 Z28 Camaro M6 – 109,567 miles on the chassis. 4-5k miles on everything else.
The car was rebuilt two years ago pretty much from the ground up. I’ve driven it very little in the last two years because I had other transportation I have put around 4k-5k miles on the car since I got it back on the road. It legally passes State Inspection and VA Emissions, its got a clean title with two accidents, very minor body work in both cases (had to replace hood and scuff/mini-dent on rear quarter panel)
Known Problems:
DTC Code 15 (CLT sensor). I have replaced the sensor in the water pump and in the head, and checked wiring for burns or breaks and everything checks out, this has been happening for the last two weeks and its been extremely hard to get to and from work… to the point where I almost lost my job today. When the car warms up its starts to run really bad I've checked everything, and have received help from the big guns here on the board.
Needs paint, its currently primed but should be cleaned up before painting.
Modifications:
Engine:
- 1995 LT1 (72k)
- Edlebrock TES headers
- Random Technology Cat. Converter
- Random Technlolgy 3” Cat-back
- PCM 4 Less Tune
- Accel 300+ Ignition & Coil, 9000 wires and NGK TR55 plugs
- CSI waterpump 160 thermostat
- Moroso CAI
- Walbro 255 fuel pump /w Racetronix harness and relay kit
- 2 row PS Cooler
- LT1 Scanmaster
- TB Bypass
- Goodyear hi-miler hoses (blue)
- Goodyear Gaterback belt
- 1LE AC delete (have all original parts for reinstallation)
- 1LE Intake elbow
- All new AC Delco Accessories (Alt, PS, LT4 KM, etc.)
Transmission:
- M6 (M29) completely rebuilt /w steel syncro’s
- SLP Billet Steel Lightweight Flywheel
- SLP Clutch, PP & Throw-out bearing
- Pro 5.0 shifter /w Lou’s short stick and MBA knob
Braking:
- Z06 Front Brake Conversion
- Earl’s Speed Bleeders
- Powerslot Rear slotted rotors
- SS Brake lints (Z06 F/Z28 R)
- Castrol Brake fluid
Suspension & Drivetrain:
- BMR KMember
- BMR Upper\Lower A-Arms
- BMR STB
- LGM SubFrames
- Spohn Adj. LCA
- Spohn Adj. TQ arm
- Spohn Adj. PHB
- GC Coilovers /w 500lb F & 150lb R
- Wolf Racing 6pt Roll Bar
- BMR 32mm/21mm Solid SB
- Strano/Bilstien Revalved Shocks for GC spring rates above
- Rebuilt Rearend (Torsen T2R Diff, 3.42 gears and Solid Pinion Spacer)
- Yokohama AVS ES100 275/45ZR17 tires & 10 Spoke SS rims (Silver)
Interior:- Corbeau Forza seats D/P
- TA door panels (not installed)
- Lightweight carpet
- White Face gauges (not installed)
- No Stereo
Extras (Never installed)
- NOS dry kit 100-150-200shot
- Remote bottle opener
- Bottle heater
- Purge Kit
Known Problems:
Modifications:
Engine:
- 1995 LT1 (72k)
- PCM 4 Less Tune
- Moroso CAI
- 2 row PS Cooler
- LT1 Scanmaster
- TB Bypass
- 1LE Intake elbow
Transmission:
Braking:
- BMR KMember
- BMR STB
- LGM SubFrames
- Spohn Adj. LCA
- Spohn Adj. TQ arm
- Spohn Adj. PHB
- No Stereo
- Bottle heater
- Purge Kit
