Emergency Brack adjustment
Old Nov 14, 2005 | 03:34 PM
RocketCutlass's Avatar
How do you adjust the e-brake on a 02 Z? i used it for the first time since i've owned it yesterday lol and it came all the way up, pulled the rotors and the shoes look fine and i couldn't find the adjusting mechanism. anyone know how?
Old Nov 14, 2005 | 03:52 PM
2001NBMZ28's Avatar
Re: Emergency Brack adjustment
Mine has done that a couple times too, but then when I pull it again it's fine. Remember reading somewhere to take up the slack you just pull up on the lever 3 times slowly? Could be wrong though -
Old Nov 14, 2005 | 08:15 PM
MustangEater82's Avatar
I have heard you are supposed to go in revers then get on the brakes hard...
I have tried it hard easy, etc.... nothing worked.
I'll try the lever thing but I doubt it works either.
FWIW I pulled the rear and driveshaft and checked everything, nothing to adjust the e-brake.
Old Nov 15, 2005 | 07:56 AM
well this is discs in the rear with the e-brake shoes set up like drums, i'll try the lever thing.
Old Nov 15, 2005 | 08:54 AM
respectirocz's Avatar
on my third gen, both sides meet to one common cable and bracket, with a nut to adjust tension
on a typical drum brake set up driving in reverse will adjust the shoes to accomodate normal wear and tear
on ls1 rear brakes, the intergral drum brake has a self adjusting screw to accomodate normal wear and tear, not for major adjustment
disconnect the driveshaft again, and follow the two ebrake cables, they should meet up to one cable/bracket, and from there you can adjust it
Old Nov 15, 2005 | 05:26 PM
RE AND CHERYL's Avatar
Wrong generation man. That worked for older drum brake cars. But not for disc brakes. Forther compounding the problem is the rear brakes are disc and the parking brake is a small drum inside the rear disc.
The parking brake handle has a small ratchet tooth in the handle that is supposed to automatically adjust it. If the handle came all the way up with little to no tension, it's probable jammed.
Old Nov 16, 2005 | 09:44 PM
Bersaglieri's Avatar
Mine just did this. Flew all the way up and broke part of my console at the top.
I'll be screwing with it tomorrow morning. I'll let everyone know how it works out.
-Dustin-
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
