Question about Displacement on Demand
Old Nov 14, 2005 | 02:14 PM
V8 Slayer's Avatar
Since half of the motor shuts down does that mean one half it will get worn more? i.e plugs, wires, seals, bearings etc....??
Old Nov 14, 2005 | 02:19 PM
HAZ-Matt's Avatar
Re: Question about Displacement on Demand
I think it alternates between halves, but I could be wrong.
Old Nov 14, 2005 | 02:33 PM
91_z28_4me's Avatar
It isn't one bank and then another. It is like first on the left second on the right. Third on left and so on.
Old Nov 14, 2005 | 02:58 PM
jg95z28's Avatar
http://www.popularhotrodding.com/fea...0405phr_gmdod/
http://www.edmunds.com/advice/specia...1/article.html
Old Nov 14, 2005 | 03:14 PM
Chris 96 WS6's Avatar
Its not as if the pistons stop moving...so as far as rings/bearings there's going to be no less wear. I suppose you'd see less valvespring fatigue and less roller rocker wear, and maybe even extended valve seal life, but as long as most of those items last normally these days I don't think its really a quantifiable benefit.
Isn't this in the wrong forum?
Old Nov 14, 2005 | 04:54 PM
R377's Avatar
Well, actually it's possible there'd be less wear on the cylinders that get deactivated. Without the heavy thrust load of power cycle, there could theoretically be less wear on that side of those cylinders. Rod bearings might also have a somewhat prolonged life.
As to whether it wears more than in an engine without DOD, I doubt it. So a DOD engine should last as long as a regular engine, except some components might last even longer.
Old Nov 14, 2005 | 04:58 PM
HAZ-Matt's Avatar
Half means the unit divided by 2, not necessarily one bank of a V engine. But my overall point was wrong.
I suppose they were not concerned with unequal numbers of combustion events in each cylinder. It is simpler and cheaper to just set it up like they did.
Old Nov 14, 2005 | 10:26 PM
30thZ286speed's Avatar
From Popular Hottrodding article on DOD:
What's more, the LZ8 is designed to work in a rear-wheel drive configuration, which would pave the way for its use in a future base-model Camaro. If that occurs, the LZ8 would trump the '05 Mustang's base V-6 by nearly 40 horsepower while returning the same fuel economy.
Interesting
From the diagrams in that article, I would say it would be very important to keep the oil very clean with fresh oil changes in the engines with DOD given all the extra oil going through small tubes to each lifter, its a pretty complex oiling system with electronic control for the oil on each lifter.
Does the LS4 with DOD have a different oil change intervals?
Old Nov 14, 2005 | 10:45 PM
HAZ-Matt's Avatar
I bet a DOD V6 would get better gas mileage than the LZ8 in a base Camaro
ChrisFrez
Mar 22, 2015 07:00 PM
ChrisFrez
Mar 22, 2015 09:12 AM
ChrisFrez
Mar 8, 2015 01:22 PM
ChrisFrez
Mar 1, 2015 01:33 PM
routesixtysixer
Jun 23, 2002 02:29 PM
