? for people w/ t-tops or leather seats.....
Old Oct 28, 2002 | 02:45 AM
02 Artic Z28's Avatar
What kind of leather cleaner and conditionor do you use to treat your leather seats?
What, if anything, do you use to treat the new seals along the window and around the t-tops?
jp
Old Oct 28, 2002 | 03:51 AM
TerrorDome's Avatar
i use eagle leather cleaner and conditioner...two step process.
no t-tops sorry
i apply the leather stuff every other week. that seems to work for me.
Old Oct 28, 2002 | 06:41 AM
Dark Angel's Avatar
For the seals, there's a silicon spray, you can get from the parts store. I use miguires leather care for the seats.
Old Oct 28, 2002 | 11:13 AM
rncotton's Avatar
Meguire's leather cleaner (not too often, only when they need cleaning) and Meguire's leather conditioner (about once a month)
I use a food grade silicone spray for all the weatherstripping.
Old Oct 28, 2002 | 12:19 PM
OctaneZ28's Avatar
Disciple
Zaino Leather cleaner (Z9) & Zaino Leather conditioner (Z10) are the only products that will EVER touch my leather seats.
They work great, and ya gotta love that Zaino smell
About once every 3 weeks is all it takes for me.
Old Oct 28, 2002 | 12:32 PM
brentasan's Avatar
Thumbs up
Dittos!! Zaino is the ONLY way to go. I use the tire protectant too which also works on ALL rubber! GO ZAINO, you won't be sorry!!
Old Oct 28, 2002 | 12:50 PM
DohHunter's Avatar
Yep, Zaino.
Old Oct 28, 2002 | 01:23 PM
supersp0rt's Avatar
another vote for zaino, gotta stick with the best!
Old Oct 28, 2002 | 01:47 PM
11 Bravo's Avatar
I had a problem with my tops leaking. I took them apart. When you do, you will see the rubber seal had some kind if black sticky stuff to "seal" the ends. I used some white tub and tile caulk on each end and put them back together. This was 4 months ago and they haven't leaked one drop. Even tested it by spraying them directly with a high power hose at the car wash. No leaks.
Old Oct 28, 2002 | 03:02 PM
ssvegas's Avatar
well in the 6 months ive had mine, i havent used any leather cleaner, i have wiped em down, but not with actual LEATHER cleaner.
for the tops i use Armoral...for now.
Old Oct 28, 2002 | 03:15 PM
LaSSt One's Avatar
For the leather seats, Zanio all the way. If Zanio didn't exist, then Lexol would be in my garage. As for the weatherstripping, I use a combo of the Z-16 tire dressing for the UV protection and for conditioning, I use Dielectric Silicone Grease (GM Part No. 12345579 or equivalent), as it states in the manual... every 6 months. You can pick up this stuff at your dealer parts counter or at www.gmpartsdirect.com. I think something in the silicone causes the strip to expand a little bit. All I can say is that it works. No leaks from my vert, used it on Mom's '99 Sebring vert to stop a leak and used it on my Blazer to stop wind leak/noise. The one thing I would NOT use is Armour All. Good luck!
Old Oct 30, 2002 | 05:15 PM
fbird95's Avatar
Saddle soap for both cleaning the leather and for the weather stripping. It reapeals water like no other and doesnt leave a greasy mess all over
Old Oct 30, 2002 | 05:40 PM
crazyswede1027's Avatar
I am a believer in Lexol for the leather. Used in another car I had worked great, now using it for my formula. No complaints. Also use a silicone spray for all weather stripping on the car, including the t-tops.
Old Oct 30, 2002 | 05:56 PM
99blackSS's Avatar
Armorall on the leather.
The only tim I had a sealing problem with the t-tops the body shop made the windows go up higher to make a tighter seal.
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
