converting zex dry kit to 150 hp
Old Nov 13, 2005 | 02:26 PM
Daniel6718's Avatar
what would i need to make a zex universal efi dry kit to handle a 150 hp shot?
can it be done with just a nx noid and some jets?
thanks
daniel
Old Nov 13, 2005 | 05:52 PM
HarrisSpeedWorks's Avatar
Re: converting zex dry kit to 150 hp
Yup, you'll have to run the fuel solenoid next to the Zex Box. We offer a conversion kit. Here's a link for more info. LINK
Matt
thanks
daniel
Old Nov 13, 2005 | 08:43 PM
Daniel6718's Avatar
i meant to keep it a dry kit jus up the capabilities to 150
run 100 most of the time occasionally bump it up
thanks
daniel
Old Nov 14, 2005 | 06:15 PM
Sorry, misread your post. You might not have to upgrade anything. All it might be is a jet swap. Depending on the orifice size of the solenoid that is. If you do need a larger solenoid to flow that amount then you should be able to swap them out of the box, you might need to get a little creative that all.
Matt
Old Nov 14, 2005 | 09:54 PM
Nitro Dave's Avatar
All you need is a jet change..Assuming your fuel system can support it.
Dave
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
