Any TTS Datamaster experts?
Old Nov 12, 2005 | 03:13 PM
camaro81's Avatar
I've been logging data from my '95 z28 using Datamaster ever since I installed the new transmission & 3000rpm Edge converter.
I noticed that occasionally it will show up a negative number in the section for "Slip RPM" under Transmission Data.
Example: Like when I tap the brake so the lock-up converter disengages, the rpm's drop to 1000-1200rpm and -500 to -700 slip rpm is listed.
Also, while crusing in 3rd gear it'll show up with -300rpm sliping.
How can my transmission have negative slippage?
Old Nov 13, 2005 | 01:12 AM
Dave '97 Z28 M6's Avatar
Re: Any TTS Datamaster experts?
Wouldn't that be when you're decelerating, and the engine speed slows down below the no-slip speed?
Would an un-programmed gear swap affect this, maybe? The slip RPM # is just a calculated value.
Old Nov 13, 2005 | 07:21 AM
camaro81's Avatar
I get a lot of negative slippage while driving too, not only while accelerating, I was just curious what it meant. I had it programmed after the gear swap not sure what all was touched by him though.
Old Nov 13, 2005 | 12:28 PM
Well, you should only see negative slip when you're decelerating, AFAIK. Mind you, my car's a 6-spd, so I don't see any slip. Actually, all the trans info is disabled in Datamaster when you use it with the M6.
Bails098
Aug 17, 2015 05:15 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Joe Brodman
Jan 1, 2003 12:59 PM
97TA-WS6-Con
9
Nov 14, 2002 10:30 AM
Steve in Seattle
Nov 3, 2002 10:37 PM
