TCS swap from another car?
dhirocz
11-10-2005, 09:06 AM
I have a '94 Z and my buddy has a '95 t/a...mine has 3 channel abs, his has TCS. He doesn't want it. We're both going to pull our dashes out to put in new heater cores this weekend. Aside from the brake lines, axleshafts, backing plates and some of the wiring, is there anything else involved? I know the dash harness comes together under the driver's dash, will the tcs body harness join with my front harness and work correctly? Or is there more involved? I'm ready to swap harnesses and BCM's and everything, just wondering about the wiring compatability because he has the pop-up headlights and I dont so I want to make sure before tearing the cars apart that I dont need anything else.
MustangEater82
11-10-2005, 09:49 AM
also can anyone show me how a TCS wheel sensor is hooked up?
Injuneer
11-10-2005, 10:53 AM
The ABS units will need to be swapped.... one is 3-channel, the other is 4-channel. You will need to run another brake line to the rear brakes.... TCS has two, ABS has one. There is an interface to the PCM, so that will require reprogramming. Not sure if you might have to also swap the EBCM modules.
Moving to "General F-Body Tech & Info".
