supercharged 2.0 ecotec VS LS2
Old Nov 2, 2005 | 10:51 PM
97z28/m6's Avatar
which one is heavier and buy how much?
Old Nov 2, 2005 | 11:15 PM
CamaroRSguy's Avatar
Re: supercharged 2.0 ecotec VS LS2
motors? ls2 is about 6k as a crate motor, the 2.0 S/C is about 4k last i checked from GM. The 2.0 4 banger is lighter...
Old Nov 3, 2005 | 06:07 AM
91_z28_4me's Avatar
He means weight wise.
Old Nov 4, 2005 | 01:39 AM
NewbieWar's Avatar
I'd think it to be common sense the engine with a third of the displacement would be the lighter engine... but seeing that there is a power adder and there is a DOHC set up...
Old Nov 4, 2005 | 02:29 AM
97z28/m6's Avatar
i need to settle an argument-thats why i need the#'s.
Old Nov 4, 2005 | 03:39 AM
FutureZMan's Avatar
safe to say if you bet on the V8 on weight, then you lost.
the 2.0 strapped with a twister is still lighter.
Old Nov 4, 2005 | 12:39 PM
97z28/m6's Avatar
well i didn't bet the V8 was lighter just how much it was heavier.
Old Nov 4, 2005 | 02:04 PM
NewbieWar's Avatar
well i tried to find you an answer, but i read on GMI that "The LS2 weighs a little less than 500 pounds"
or we can go with the ls1 weight of "total dressed engine weight (2001) LS1 auto 457.6 lbs (208kg) manual 497.2 lbs (226kg)"
the ls2 is bigger but uses lighter components so... that sounds about right to be barely under 500...
and the only number i could find on the ecotec was 303 but i think that was incorrect... sorry i'm not more help for you
Old Nov 4, 2005 | 02:50 PM
Z28x's Avatar
THe LS2 is actually lighter than the LS1 by something like 15lbs. (I forget the actual difference. Do a search of this forum, there are threads on LS2 and DOHC engine weights.
Old Nov 4, 2005 | 10:31 PM
97z28/m6's Avatar
thanks none the less.
Old Nov 5, 2005 | 01:40 AM
RussStang's Avatar
Bare engine weight for the LS1 comes in somewhere around 390lbs I believe. That is longblock only however. I also remember reading the LS2 is around 15lbs lighter than the LS1.
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
