12 Bolt Install
Old Nov 2, 2005 | 04:39 PM
GMCAMARO's Avatar
12 Bolt Install
12 Bolt Install
I am doing a Moser 12 bolt install.
I have the calipers removed from their brackets. According, to the directions I have read, I am supposed to be able to remove the rotors and the caliper bracket. I have tried to loosen the four bolts that hold the caliper bracket in place but both the nut and bolt turn. How do you remove the rotor from a 99?
Old Nov 8, 2005 | 08:20 AM
mzgp5x's Avatar
Re: 12 Bolt Install
I just did a moser 12 bolt on a 1997. I thought the cal-bracket was the same on later models. Just four bolts on the old, I think a 3/8 of 15mm socket. The bolt hole on the bracket in counter sunk. After you pull the C_clip axels, you can get @ them. Besure to mark LH and RH to reinstall. They assemble on the Moser axle, and, it is a press fit if you go with NON-c_clip type. Had to purchase a new drive shaft. 1350 yoke, so, I went with a denny HD. Waiting for it now.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
