ABS not working??
matLT1
10-29-2005, 10:11 PM
The problem I am having is that in wet weather if I get on the brakes (medium pressure or more) all four tires will lock up and I will go for a fun slide til I let off the brakes. At times on dry pavement they will lock up too. I still have plenty of tread left on the tires so that shouldn't be the cause. And they are Aquaflow tires, so in theory they should be descent for wet pavement!! Do you guys have the same issue with your cars or could this be an ABS issue? Thanks
97formula1234
10-31-2005, 10:45 AM
It sounds like your abs is not working, Is the ABS INOP light on on your dash?
matLT1
10-31-2005, 11:36 PM
No, the light isn't on. Someone was telling me I should check the abs fuse out. I think I'll try that.
jakesnake123957
11-06-2005, 07:20 PM
MY 94 does that too and its the ABS ,I was almost killed a week ago,better fix it man!
69gto96z
11-17-2005, 10:33 AM
Mine does the exact same thing. I wanna figure out what is up. I have almost been killed from it also, in the rain one time. But only my front's lock up. And I dont have an ABS light on.
jakesnake123957
11-17-2005, 04:50 PM
Yeah man my rt front locks up all the time in the rain,I am pretty sure its my accumulator.>Jake
69gto96z
11-17-2005, 10:26 PM
Whats an accumulator? Somebody told me I might have a bad jumper, but that seems like it would cause the ASB INOP light to come in, atleast I think it would.
jakesnake123957
11-20-2005, 10:09 PM
That is the part on left side of car and with all the brake lines going to it.
OBE1 95Z28
11-21-2005, 11:07 PM
All the brake lines go to the ABS module as you can see in the attached photo courtesy of Shoebox
http://shbox.com/1/abs_wiring.jpg
