Donohue96M6Z28
10-27-2005, 08:48 PM
how do you get the trans fluid to get back in the trans??? its not like i can poor it or anything, let me know ifyou can help
thanks
thanks
what different ways are there to get trans fluid back in my 6spd?Donohue96M6Z28 10-27-2005, 08:48 PM how do you get the trans fluid to get back in the trans??? its not like i can poor it or anything, let me know ifyou can help thanks FuryZ28 10-27-2005, 08:53 PM Go buy a siphon pump. Not only can you pump new fluid in with it, but you can also suck the old fluid out as well... Janny 10-27-2005, 08:53 PM There's a fill plug on the side. Unscrew it and pump the oil in. A pump wouldn't cost much more than 10$ I'm sure. Or take the shifter off and dump a gallon in there. Done. SantaCruz163 10-27-2005, 08:59 PM Remove your shifter and and the fill plug. Start filling the fluid from the shifter area and once it spills out of the fill plug your done. A lot easy that way. Donohue96M6Z28 10-27-2005, 09:01 PM well im having problems even checking it. i cant get under my car(dont have any toolsd where im living), anyway to get around checking it from underneath? if i was low would i notice trans problems, or would it just start tearing stuf fup? Donohue96M6Z28 10-27-2005, 09:21 PM also is there anyway to fill from the shifter without taking out the filll plug StrokinIt383 10-30-2005, 04:48 PM also is there anyway to fill from the shifter without taking out the filll plug Yes but you dont want to overfill it. That is the purpose of removing the fill plug. You just fill it until it starts to come out of the fill hole. Make sure youre on flat ground though. You dont want to overfill or underfill. Its so simple and not to mention easy to get to i dont see why there would be a problem removing it. Its on the drivers side and all you need is a 3/8" extension. Hope this helps. | ||
