Laughing69Camaro
10-26-2005, 12:40 PM
I bought my 1997 Z about 2 years ago. It had 43000 miles on it and the person I bought it from said that the 6th gear shift fork was going bad. I also believe this to be true. It was hard to get into 6th, but now it wont go into it at all. My questions are, does GM carry the steel shift forks, or is that an aftermarket item? And how hard is it in replacing the shift forks? Since I will be in there, I might as well replace all the shift forks with steel. If anyone has all the part numbers, that would be great. Also, I just put a Hurst shifter in it and 4th gear is now giving me trouble getting into gear. I do not shift hard at all. Do I need to adjust the stops on the shifter?
Thanks Bass
Thanks Bass
