Quick help on WS6 Eibach springs
Old Oct 22, 2005 | 01:45 PM
Camarocracy's Avatar
I need some quick information pertaining to factory eibach springs.
My car is a non-WS6, and I want to put on the Eibach WS6 springs on. I know I would need the SLP revalved Bilstein shocks for them. But would I need an adjustable torque arm, and adjustable panhard bar, and LCA relocation brackets? The drop wouldn't be more then .5", I don't think that would be severe enough to require all of those new parts would it?
P.S. Is the WS6 Eibach's the same as the SLP Level I or Level II springs?
Old Oct 22, 2005 | 08:34 PM
Bersaglieri's Avatar
Re: Quick help on WS6 Eibach springs
No, no, no. You dont need any of those. Relo brackets are prefered to get a better angle for the LCA's to function better with a lowered car. The ADJ PHB is preferred if the rear is not centered with a lowered car. So you can adjust the rear to set it back to center. I dont think you'll have much problem with this since WS6's had the same exact PHB that came on every other F-body and the springs only lower .5". ADJ TQ ARM is not necessary at all in my opinion until high power begins to apply. Definately not on a relatively stock car. I'd ask Strano what he recommends as far as shocks for that combo, it might be so close to stock HD's might work. Although Strano knows best.
I dont know what level any stuff is, all that seems like a blur of hazy information. If you dont end up taking them I might.
-Dustin-
Old Oct 23, 2005 | 11:16 AM
Any other info on the springs?
camaro98_speed
Apr 22, 2015 11:26 AM
Dec 1, 2014 08:08 AM
