lt1 wet kit
Old Oct 20, 2005 | 01:20 AM
Daniel6718's Avatar
lt1 wet kit
ok ive heard good things about the single nozzel kit from nitro dave...
and ive read about the pro fogger kit from harris speed works...its 70 bucks cheaper and says it has more capability...
but doesnt nitro dave have better parts???
i wanna do a 125 shot wet kit...ive got ngk tr6 now i just need a window switch what type do yall recommend??? and timing to pull about 4 degrees, what do yall recommend??? and...is there anything that does both???
daniel
Old Oct 20, 2005 | 02:26 PM
HarrisSpeedWorks's Avatar
Re: lt1 wet kit
We have a few new kits coming out; one of them will be a single/dual nozzle kit. The nozzles are aluminum with a .110 orifice and the solenoids are the "3 port" style so your purge will connect directly to it. The nozzles are able to accept either style jet on the market too (TNT, NX style and the NOS style).
The CFN kits are great too and we're going to continue to carry/support them. If you are looking for a 125 shot they are hard to pass up and come with a lifetime warranty.
Since you have a LT1 look into a new ignition system to pull timing. Most of them also have an integrated window switch too.
Let is know if you have any other questions.
Matt
daniel
Old Oct 20, 2005 | 02:39 PM
LWillmann's Avatar
Re: lt1 wet kit
The Mallory 685 ignition box has a window switch, rev limiter, and timing retard all built in.
Old Oct 20, 2005 | 04:47 PM
Daniel6718's Avatar
Re: lt1 wet kit
i cant find a link to that 685 anywhere??? where is it at??? (found it for 229)
or does anybody recommend msd digital 6 and gettin a window switch on top of that??? (cant find this anywher either but msd
thanks
daniel
Old Oct 21, 2005 | 04:23 PM
Nitro Dave's Avatar
Re: lt1 wet kit
You are correct.
Our systems are THE TOP QUALITY parts.We use a better bottle valve,bigger higher flowing lifetime warrenty solenoids with the original 3 port nitrous solenoid,quick release style bottle brackets,Patent shark nozzle(better attomization).14 foot main feed line,2 foot lines from solenoids to nozzle.Our Nitrous Outlet wet kit is only 499.00.Thats a small price to pay for the best quality available If I can do anything to help you please let me know.
Dave
Old Oct 22, 2005 | 01:26 AM
Daniel6718's Avatar
Re: lt1 wet kit
nitro dave...i sent you a pretty long pm...prolly should have emailed...when u get around to respondingif u remember u can email me back
dearraff@comcast.net
thanks
daniel
Old Oct 22, 2005 | 07:54 AM
LWillmann's Avatar
Re: lt1 wet kit
thanks
daniel
Mallory 685 from Summit: http://store.summitracing.com/defaul...=egnsearch.asp
Mallory 685 from www.malloryperformance.com: http://www.malloryperformance.com/Pr...inselection=14
Mallory 685 Installation instructions: http://go.mrgasket.com/pdf/685_6851.pdf
alphaauto
Jan 23, 2015 07:42 AM
JamesN1830
Sep 11, 2002 10:57 AM
rje
Sep 9, 2002 12:35 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
