Who makes dual/dual exhaust tips with a 3" inlet?
Old Oct 19, 2005 | 07:49 AM
Kurt Crosbie's Avatar
I've got 3" dual exhaust dumping at the axle, and i want to run it under the axle and out the rear passages on the bumper on my TA. However, I don't know if there are any dual/dual style tips that fit on 3" exhaust. I do not want big single tips.
Old Oct 19, 2005 | 09:20 AM
leadfoot94's Avatar
Re: Who makes dual/dual exhaust tips with a 3" inlet?
I am also curious about this...
Old Oct 20, 2005 | 12:18 PM
Resilient94LT1's Avatar
Corsa may have the tips you're looking for. Check em out. www.corsaperf.com
Old Oct 20, 2005 | 12:27 PM
pHEnomIC's Avatar
Corsa makes it and so does Slp and borla.
Old Oct 20, 2005 | 07:03 PM
Is reducing from my 3" to the 2.5" hooker tips a bad idea for performance or sound?
Old Oct 21, 2005 | 08:32 PM
If you're downsizing tips...there won't be any notable difference in hp or sound. If you're downsizing tubing from 3" to 2.5", then you're causing more restriction, thus decreasing hp... but so little it almost doesn't matter (to most).
Old Oct 21, 2005 | 08:55 PM
So I would be better off just putting 2.5" tips on rather than reducing the 3" piping from the axle to 2.5" piping at and after the axle to accomodate the tips at the bumper?
How much of a horsepower and sound difference are we talking about?
Old Oct 21, 2005 | 10:30 PM
I wouldn't even start to try giving you numbers, because the difference is so slight. Sound wise, it would probably take a trained ear to notice. What kind of exhaust are you using? Regardless of pipe size, i'm sure most people would be like, "that's badass" just because of the muffler. In terms of a stock set-up, I believe the piping was 2.75 from the axle foward, and reduced to 2.5 or even 2 into the muffler and out to the tips. So any increase from there is beneficial.
Old Oct 21, 2005 | 11:34 PM
I currently have longtubes w/3" x-pipe and 3" true duals stopping at the axle.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
alex5366
Feb 17, 2015 09:07 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
YellowTransAm350
Mar 2, 2003 03:38 PM
