gauge cluster
blazzinbird
10-16-2005, 08:20 PM
will the gauges froma 97 t/a work in my 96?
sorry if this is in the wrong forum
EKO
10-17-2005, 12:34 PM
I don't think they line up.
95HellBird
10-17-2005, 12:38 PM
it'll fit as long as its not digital otherwise you gotta getta different cpu setup, and then you got to take the speedo to a pontiac certified shop and get them to set the gauge to your miles.
Fastbird93
10-17-2005, 08:07 PM
Actually, the 97 digital clusters WILL work in a 93-96 Firebird. Both of my 93 Trans Am's have the 97 digital clusters in them. Everything works as advertised with exception to the fasten seat belt light (doesn't go off) and the TCS OFF light (again, doesn't go off). It's a simple process to open up the cluster and block off those lights though.
Honda Hunter
10-18-2005, 09:04 AM
If that's the case then the 97 T/A will plug into the 93-98 camaro? Also was 1997 when the T/A went digital?
Fastbird93
10-18-2005, 04:56 PM
I'm not sure if it will plug into a camaro or not. Never tried that. Mid 97 is when the gauge cluster swapped from the analog to digital odometer.
