Demus
10-16-2005, 07:32 AM
I'm going to weld together a simple CAI and in the process of doing that I ran into a few questions. Should I try and keep the pipe the same size as the throttlebody? I have a 58mm throttle body, which works out to 52.8148 cm^2 surface area.
The MAF has a diameter of 8cm, and the divider has a width of 1cm in the middle. In total 3.14*4^2-8*1= 42.24 cm^2. My vortec intake elbow has a surface area of 48.145 cm^2 on the TB side, and 44.606 cm^2 on the other side.
In a perfect world would the MAF and elbow all be 52.8 cm^2 to match the intake? Or does it really not make the much of a difference?
