OBD1 High Stall Problem
TobyZ28
10-15-2005, 05:51 PM
What table(s) in Tunercat do we have to change to fix the high stall problem in OBD1?
97Z-M6
10-16-2005, 11:20 AM
ive fix several of them but you need to be sure its the stall and not tranny slipage or something.
waht size stall do you have?
TobyZ28
10-16-2005, 09:38 PM
None yet. Want to do my homework before I buy one so I'll know what to change in tunercat w/ it. :) Would be awsome if i could find some information on what table(s) relate to this.
97Z-M6
10-17-2005, 06:06 PM
sorry been gone this weekend.
im sorry i cant share what tables it is. theres one in the constants tables and some and the main tranny tables. if you get a stall i will help you if send the bin file to me. but i cant tell you what the table are because i told the person that told me i wounldnt tell his his secrets.
just a heads up, some people say that some times the fix dont work. but ive had 4400 stalls do great for a daily and preform great at the track. never not been able to fix one from tuning.
chevy94c
10-17-2005, 06:51 PM
I am having the high stall problem. I just need a tunercat.
Mean Green Z28
10-17-2005, 11:58 PM
Would you charge for this? I'm thinking of getting a convertor but am not looking into higher stalls 'cos of this problem, although my cam likes higher RPMs. This would help out immensely. I've asked about the fix but nobody's willing to say, you're the first person who's actually said you'd be willing to help, I respect you for that bro! :bow:
97Z-M6
10-18-2005, 12:07 AM
no i will not charge, but if you go and by a 3600 stall. theres no garuntee i can fix. but im willing to help and try.
ive fixed 9 or 10 of them for people on this board, and have never charged and never will. im here to give all the help and info i can give, and in exchange ill take all i can get from the other people on the board.
Mean Green Z28
10-18-2005, 12:12 AM
Good man!
shoebox
10-18-2005, 08:44 AM
I seem to remember some information posted in this forum in the past...or maybe my memory is failing. :)
Honda Hunter
10-18-2005, 09:30 AM
Actually there alot of ifo I found out while searching this issue. First thing I learned is this seems to be a huge big secret for some reason. I have the fix but never had the chance to use it before taking the motor out in preperation for a 383 so I dont know for sure if it wouldve worked for me. My only question after looking at the tables etc is does the fix has it's cons? Does it slow you down etc?
Deenasty
10-18-2005, 02:43 PM
First off I would like to thank 97z-M6, for his response in willing to help fellow members, there are not too many out there like that. Second, I am thinking of doing a m6-A4 conversion, and will be running an Edge 3800 stall. I am trying to do a little research on this high stall problem, or sometimes referred to as "Stall wall". Is there a for sure fix for this? I am running OBD 1 as well. Also I didnt mean to hi-jack this thread. The question I have asked also pertains to the information trying to be seeked by the thread starter. Thank You!
Honda Hunter
10-18-2005, 03:54 PM
From the research I did with the search and from everything Ive read everyone will tell you to get it done by pcm4less, Ion, or Fast chips. No one will openly say what exactly it is.
TobyZ28
10-18-2005, 03:55 PM
I found some stuff out. I'm going to post it when i have some time later this afternoon :)
95WhiteTA
10-18-2005, 05:58 PM
Hey, i'd like to do a M6 swap in the near future, so if you wanna swap tranny's i'd be down, i've had a recent rebuild and currently have a 3200 stall. Just a thought, if you havent already bought an automatic.
95WhiteTA
10-18-2005, 07:07 PM
i know some people change to obdII to fix the problem, how hard is it to change to OBDII? Do you have to change the whole wiring harness or could you hook up your PCM plugs to the OBDII pcm and just get a tune with the crank sensor and rear O2's removed? I think that's the only 2 main differences between OBDI and OBDII.
97Z-M6
10-18-2005, 07:48 PM
there is a garentee fix by ed wright, but remember if ed tunes your car, you cant scan it nor can you change programming. so your stuck
i did get the fix from one of the above names, but it wouldnt work on the 4400 stall, i had to change 2 other tables. in order to make it work. and it has not failed me since. and none of the persons mentioned above will garentee the fix but ed.
it took about 12 hours to figure out the fix for the 4400 stall, and it was acctually a better driver than the 2800 stall he had before, but the drive quality took alot of torqe covertor tuning.
Honda Hunter i have never heard any bad issues from this, and ive heard back from all but one person i helped.
95WhiteTA
10-18-2005, 07:57 PM
Hey 97Z-M6, i've got bryan at pcmforless changing my tune for my 3200 stall, do you mind if i send you the file and let you look it over to see if you can further perfect it?
97Z-M6
10-18-2005, 10:25 PM
yeah send it on. vincentbergeron@yahoo.com
load it first and see if it works. you might not need to send it. but ill look at it.
send it on
95WhiteTA
10-18-2005, 10:33 PM
ok, i sent you the .bin file. I cant load the tune till i put my cam in cause the tune is for a Lt4 hotcam plus he threw the stall fix in there too. I could have got him to make another one with just the stall fix and no cam, but i didnt wanna make him go through all that.
Honda Hunter
10-19-2005, 02:48 AM
Why cant you scan or change the programing? Is it really possible to stop someone from doing it??
Deenasty
10-19-2005, 02:54 AM
he locks your file..I think you can still scan it, but not download the file or alter it..
Honda Hunter
10-19-2005, 03:52 AM
That's BS. No fix is worth that much. Now I want one of his files so I can unlock it and feel better.
Mean Green Z28
10-19-2005, 04:08 AM
lol ... yeah, the professional/shop versions of most of the Edit sofware let you lock the tune ... interlectual rights yo! pretty gay but how would you feel if you spent countless hours fine tuning and fixing shyt and someone just coppied it and made mad dough with it? This is why I preffer to learn to tune my own car so I save a bunch of money and get the satisfaction of saying I did EVERYTHING!
Honda Hunter
10-19-2005, 04:14 AM
I guess I understand. Still pisses me off though. Hey Im from Gaithersburg as well.
Deenasty
10-19-2005, 02:26 PM
well i spoke to Bryan Herter over at PCMFORLESS this morning, and he said he has a for sure gaurantee fix for this problem. He states "the VSS signal goes crazy because the tail shaft flexes, and sends the computer into limp mode." But he has the fix.
95WhiteTA
10-19-2005, 04:35 PM
yeah bryan did the fix for me, i cant load the tune in yet and prove it worked. He told me the same thing, the tailshaft flex on a hard launch sends the computer into limp mode or something and it just shifts into 3rd and stays there to you get off the gas for a few seconds. He said some cars actually got stuck in 3rd gear till you cut the car off tho. My car took off, then would bogg and rev up but go pretty slow, cause it stuck in 3rd gear and wouldnt drop down till i let of the gas for like 3-5 seconds.
95WhiteTA
10-19-2005, 04:47 PM
Deenasty
10-19-2005, 05:16 PM
95whiteta, I sent you a pm, waiting for your reply..
Dan K
10-19-2005, 10:15 PM
There is no trick to fixing it. On a hard launch, the vss loses signal and the computer goes into "limp" mode.
You need to make it so that the pcm doesn't use the vss for it's wot shift calculation.
...wow, this is the first time I've posted in here in a while. :)
97Z-M6
10-23-2005, 10:19 AM
looks like it should work. but for a stall thats above 4000 i would change one more table but it should work for you
95WhiteTA
10-23-2005, 01:36 PM
I'm guessing that post is for me? Is so, thanks for checking it out.
-Tim
97Z-M6
10-23-2005, 02:17 PM
yes it was for you. soory about how long it took to get back to you.
it been a very long long week
