FS: '01 Black m6 Formula(pics inside)
Old Oct 15, 2005 | 12:19 PM
4mulaJoe's Avatar
*Chassis/Suspension
8 Point Roll Cage
Strange 12 Bolt Rearend With Posi 3.73, 3" Arp Studs
Wolfe Anti-Roll Bar Kit
LT1 BRakes
!Parking brake
Bmr Trak Pak Torque Arm with DS Safetly Loop
Lakewood Lca's
Lakewood Adjustable Panhard Rod
Hotchkis Boxed Subframe Connectors
Poly Motor And Trans Mounts
*Engine/Exhaust/Etc
Less Than 2K Miles On Fresh Shortblock
347 With Diamond Ceramic Coated 11.3:1 Dome Pistons With -2Cc Reliefs
JE Rings
Eagle H-Beam Rods With Arp Rod Bolts
Clevite Main And Rod Bearings
GTP Stage 2 5.7L Heads Milled .030 With Cmotorsports Valve Springs And Titanium Retainers
ARP 12 Point Head Studs
Comp Cams R Series Lifters
FMS Custom Grind Camshaft - 224"/230" .588"/.595" 114LSA
Ls6 Intake
Dynatech Long TUBE Headers With custom y-pipe and hooker catback
ASP Crank Pulley
Whisper Carbon Fiber Air Lid
Custom PCM Tuning
*Fuel System
Walbro 255 In-Tank Fuel Pump
TNT F1 Nitrous Kit
*Transmission
Fully built m6 (less than 1k miles)
spec stage 3 clutch(also less than 1k miles)
pro 5.0 shifter
Custom Heavy Duty DS
*Exterior
Suncoast Ram Air Hood
OEM ZR1 wheels with nittos on back and F1's up front
Tinted Windows
*Interior
Back Seats Removed
G-Force 5 Point Racing Harness and stock seat belts
Battery Relocated To Trunk In Aluminum Sealed Box
The car went 11.0@123 MPH in 70* humid weather with the fresh motor.
This was with a soft 1.6 60ft due to the 28" slicks/3.73 gearing/3k stall used with intentions of running it on the bottle.
Odemeter reads 21k miles.
$14,900 obo
Contact Joe at evans_tx@yahoo.com or call 281-413-9093. If I don't answer just leave a message and I'll call you back soon.
Old Oct 17, 2005 | 03:02 PM
fast96lt4's Avatar
Re: FS: '01 Black m6 Formula(pics inside)
How is driveability? Gas mileage? What is the lowest you'll take?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 13, 2015 09:52 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
omarECD
Aug 19, 2002 07:28 AM
