Bad wheel bearing?
Old Oct 14, 2005 | 03:23 PM
Paul87's Avatar
Bad wheel bearing?
My front right tire is worn very badly on the outside part, and I get a whirring sound anytime the car is going towards the right side when going 40+
Appreciate the help guys
Old Oct 14, 2005 | 07:54 PM
n2ceptor's Avatar
Re: Bad wheel bearing?
Your hub assembly is prob bad.... Change out both, so you dont have to do the other side later on.... Cost around 70-80 dollars each....
Easy to replace... Only 4 bolts to remove...
Old Oct 14, 2005 | 07:56 PM
bolek's Avatar
I have the same thing, except it's both tires, and I am
also thinking it could be the bearings.
Old Oct 14, 2005 | 08:18 PM
HotwhipT/A's Avatar
I'm also getting a new one because either the bearing or the speed sensor in there makes ticking noise at speeds of 30+ and it f'ing annoying. I am 100% sure its not the brakes, clutch, exhaust, or engine. I've tested everything!
Old Oct 15, 2005 | 12:35 AM
Paul87's Avatar
Do I have to remove the rotors, pads, etc.?
BTW thanks a lot for your help guys, I truly do appreciate it
Old Oct 15, 2005 | 10:22 AM
gt_biker13's Avatar
"Do I have to remove the rotors, pads, etc.?"
Yes, but its not hard at all, you wont need to remove the calipers or anything so its a stright forward swap.
carl.froehlich
Mar 13, 2015 12:38 AM
warmeck
Mar 8, 2015 08:01 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
chuyz28
Nov 25, 2014 11:14 PM
