afpr needed?
Old Oct 13, 2005 | 09:44 PM
mw's Avatar
mw
afpr needed?
If your injectors are large enough to handle your power output will it cause any problems tuning if you just have the factory fuel pressure regulator?
I'm guessing that it doesn't see "boost" so the fuel pressure will quit rising at 43psi. Can this be taken care of with tuning or is an afpr like the aeromotive needed?
Old Oct 14, 2005 | 09:34 AM
markinkc69z's Avatar
Re: afpr needed?
The factory regulator is manifold referenced so it would see boost and rise at a 1:1 rate with boost. Your additional fuel will be taken care of by ecu tuning.
Old Oct 14, 2005 | 10:58 AM
mw's Avatar
mw
Re: afpr needed?
Thanks, just wasn't sure if it could "see" anything oter than vacuume.
Old Oct 15, 2005 | 09:10 AM
97WS6Pilot's Avatar
Re: afpr needed?
Are you sure about this? If the stock regulator rises on a 1:1 ratio to boost then why do some people(me) use ati's fmu's to increase fuel pressure?
Old Oct 15, 2005 | 09:30 AM
Alvin@pcmforless.com's Avatar
Re: afpr needed?
+Because they do it at a higher rate.. 4:1 10:1 etc
Old Oct 15, 2005 | 10:54 PM
97WS6Pilot's Avatar
Re: afpr needed?
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
CobraEatr
Jul 24, 2004 11:37 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
