BMXbandit
10-13-2005, 10:42 PM
what is the best way to go about taking the z28 emblem off the rear?
removing rear z28 emblemBMXbandit 10-13-2005, 10:42 PM what is the best way to go about taking the z28 emblem off the rear? kick Z tail out 10-13-2005, 10:56 PM How did it get there in the first place? :confused: ;) samualt 10-13-2005, 11:44 PM I thought the "Z28" was part of the bumper. It just sticks out a little. Moulded. Perhaps I'm wrong. Many people add a vinyl graphic on top of the "Z28" to make it a certain color. You might remove that and just show the paint underneath. If there is a vinyl graphic there. My car had a bowtie that did come off. It was just on there with double sided foam tape. It was hard to tell it was tape till I pulled hard on it. CrabhartZ28 10-14-2005, 12:07 AM heat it up with a blow dryer and use some fishing line to remove it. Then use some goo off or something to get that glue off. Same way you remove side molding. gt_biker13 10-14-2005, 01:06 AM Fishing line... thats a good idea, which i knew that a month ago. Just make sure you get it warm/ hot but be careful if you use a heat gun. Goo gone wroks well but its going to take quite a bit of time. BMXbandit 10-14-2005, 02:44 AM thanks for your help guys. i was able to get the emblem off easily and get it on the car. http://img.photobucket.com/albums/v212/skittes934/Katie_Berger01.jpg http://img.photobucket.com/albums/v212/skittes934/Katie_Berger02.jpg | ||
