93-96 to 97 dash and center
Honda Hunter
10-13-2005, 10:26 PM
I know this question has been asked alot but all I need is a parts list of exactlly whats needed to upgrade the dash. Also if the car is convertable will that make a diff?
Z95m6
10-13-2005, 11:15 PM
You will need the dash, dashpad, gauge cluster, gauge cluster plug in, gauge cluster trim, AC/Defroster controls, AC ducting, fuse panel cover, radio, radio trim, and A-pillars from a 97+ camaro or a 93-02 TA/Bird.
Honda Hunter
10-14-2005, 08:30 AM
You will need the dash, dashpad, gauge cluster, gauge cluster plug in, gauge cluster trim, AC/Defroster controls, AC ducting, fuse panel cover, radio, radio trim, and A-pillars from a 97+ camaro or a 93-02 TA/Bird.Will it have to come from a vert or are hardtop and vert pieces the same except for the pillers?
Z95m6
10-14-2005, 03:09 PM
I can't answer that 100% for sure, but i'm pretty damn sure the dashes are the same just the A-pillars are different. If you do a search under my name and dash swap you'll see i've posted a link to a little "how to" guide many many times. I just don't feel like searching for it right now.
