FS: ls1 6.0L heads- ls1 automatic trans
Re: FS: ls1 6.0L heads- ls1 automatic trans
Originally Posted by 315plus
about 10,000 miles fully assembled lq9 heads, excellent condition $300
4l60-e out of 98 camaro with 3X,XXX miles worked perfect $400
Originally Posted by Beertestr
Trans with converter? Take $300?? I need it for my truck. Where are you located? And mods to the trans or bone stock??
yes w/converter stock trans(shifted good) i will take $300... i am in sterling heights
I'd like to check out the trans sometime this weekend if possible.
Thanks.
There should be a 4-character codeon a label on the top pf the main part of the trans case... can you tell me what it is?
Thanks.
Thanks.
8FFD, does that sound right?? you can come check it out this weekend
Yes, that is the correct one for an LS1 Automatic. I am just checking other compatibility concerns with putting it in my truck. Most of it will be custom anyway (4.8L V8 in 93 GMC) but I wanted to make sure there are not major roadblocks...
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
