Data Login with TTS Datamaster
95TAMaddog
10-11-2005, 07:46 PM
:confused: I have a 95 TA and I have TTS Datamaster. They told me when I got it that my computer is an obdI but I need a obdII cable. I can't get it to work. I plug it in and the check engine light come on and stays on and the fan stays on the entire time, but I can't get any readings on it. Please help. I need to see what is going on. :confused:
Hughey Bellue
infinitebird
10-11-2005, 11:04 PM
Are you plugging it in before you turn the car on? If not try that. Are you sure you have the right port selected in datamaster?
shoebox
10-11-2005, 11:06 PM
Did you buy the correct cable?
95TAMaddog
10-12-2005, 07:31 AM
I have the obdII cable
shoebox
10-12-2005, 09:07 AM
If it is a pure OBD-II cable, it is the wrong one.
There is a special cable for the OBD-I computer with OBD-II shaped DLC.
95TAMaddog
10-12-2005, 08:35 PM
where can I get the cable
shoebox
10-12-2005, 11:39 PM
Where did you get the one you have now?
http://akmcables.com/
and
http://wotelectronics.com/
are just two places you can get cables. There are lots of others.
95TAMaddog
10-13-2005, 10:17 AM
I got it from tts datamaster. It cost 100 bucks
Mean Green Z28
10-18-2005, 12:44 AM
considering that datamaster sent you the correct cable, have you checked to see if your computer detects the cable and what COM port it uses? Go to system/hardware and check COM ports to see if it detects the cable and what COM# it is. When you go to record, make sure you select the correct COM# in the record window under setup.
If this doesn't work, kill the sale team at datamaster and get a cable from AKMcables.com for a '95. It's basically a the same cable as the '94 (OBD-I) but with the OBD-II plug. I got the one that has a Y and has BOTH types of connectors 'cos I work with various years.
67fso
10-18-2005, 01:35 AM
Try this one for your 95 for $40:
http://www.aldlcable.com/sc/details.asp?item=aldlobd2
