speedracer69
10-09-2005, 05:38 PM
i have tuner cats thing
help!!
help!!
looking for a 383 CC306 with 58mm tb tunespeedracer69 10-09-2005, 05:38 PM i have tuner cats thing help!! speedracer69 10-09-2005, 05:45 PM Here is some more info I just need a base tune because my out computer got wiped out. Its a 383 with ported heads. 1.6rr 58mm TB G2 Mass Air 42lb ford injectors no cats, no air pump it has the comp cam 306 running 45psi on fuel 255gph pump. I got the tuner cats program and the cable. Can someone please help turbo_Z 10-09-2005, 11:56 PM www.madz28.com www.pcmforless.com Mean Green Z28 10-18-2005, 01:05 AM I can send you a file for a Lingenfelter 383 with a custom Joe O. cam and heads, not sure if it'll work with all your mods though ... also, if you want it, I'm not responsible for any mishaps if you use it. What you COULD do is, compare the file with your tune and see what you need to change (within reason) to come up with your tune. You'll obviously have have to use your injector #'s and do sometuning on the MAF tables, but you should have an overall idea of where you're going. I'd suggest getting a scanning software like Datamaster (I like the interface on it) and logging some drives and tune accordingly with the VE/spark/MAF tables. The main thing is to creap up on your final tune, rather than making big changes all at once. It'll take a while, but you'll get the hang of it after a couple drives. | ||
