removing ABS and traction control
Old Oct 6, 2005 | 09:56 AM
StripedFomula's Avatar
i have a 96 formula with traction control and ABS.
when i installed the procharger i had to relocate the traction control, i would rather remove it completely along with the abs. i found this kit here to do ithere but im not sure which one to get. there is a 3 channel one and a 4 channel one. i have 2 brake lines comming from the master which go to the ABS unit. then 2 lines come out for the front and one for the rear. which would lead me to think i need the 3 channel. BUT the one that goes to the rear gets split in the traction control and then i have 2 going to the rear also. so do i get the 4 channel or does the 3 channel come with a T fitting for the rear?
Old Oct 6, 2005 | 01:09 PM
96PTKZ28's Avatar
Re: removing ABS and traction control
One problem, it doesnt state anywhere on the site if I am not mistaken that the ABS delete kit takes the ASR traction control into consideration as well. I just called the company because I would like to do the same thing you are doing. I am pretty sure your car is 4 channel ABS. I talked to another guy on here that used this same kit and he mentioned getting a non asr throttle cable from GM. Then all you have to worry about is the hydraulic side which hopefully this kit will cover. I will let you know what I come up with.
Old Oct 7, 2005 | 11:00 PM
camaronutt's Avatar
ABS with Traction Control is a 4 channel setup. I will be puchasing the 3 channel(no trac control) kit for my car with the line lock kit from SJM.
Old Oct 8, 2005 | 09:43 AM
96PTKZ28's Avatar
Talked to a guy from SJM today and he informed me that the delete kits they have for the 4 channel do indeed address the traction control as well. So now all you have to do is decide if you want the kit with or without line lock. I am going to order mine today! Finally, no more traction control!!! Good luck.
Old Jul 30, 2006 | 04:11 PM
merim123's Avatar
How did this workout?
Old Sep 16, 2006 | 07:16 PM
SpdFrk1990's Avatar
Bump for a update of people who have done this.
Old Sep 18, 2006 | 08:09 PM
joe-96z1le's Avatar
I'd like to know also. For those that have deleted ABS, how do you like it?
Rod Bender
Nov 7, 2023 02:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
