need some traction!!!!
viper03af
10-01-2005, 06:30 PM
I have goals of 10.99 with my v6..... street tire's are not cutting it on the road right now it gets scary at the top of 1st and 2nd :eek: also i can't lanch on these for nothing lol
i want a street legal one so i can drive to the track. i see tires that i can put on my stock wheels and use those, then i see the ones for 15inch rims and use tubes, i know the wrinkle wall is better....... but that gets expensive fast with the tubes....... and rims and everything !! plus i think i seen the 15's take some modding to get them on :(
i don't want to go all out and have tire that should/could work on a 9 second car. then again i don't want to cheap out and not have what i need for my goals...
any suggestions on a set?
AW/whiteZ-28
10-01-2005, 07:38 PM
Well you could either get dragradials for your TT2's or just get some slicks for a pair of cheap saladshooters. I would do the latter.
Nice ride btw :)
viper03af
10-01-2005, 07:42 PM
Nice ride btw :)
i'm think of some 255/ MT's
AW/whiteZ-28
10-01-2005, 08:01 PM
These you mean?
http://store.summitracing.com/default.asp?Ntt=slicks&Ntk=KeywordSearch&DDS=1&searchinresults=false&N=0&target=egnsearch.asp
That's be fine I guess. Some have said they are better than et streets
Oh and I see your wheels are smoothies not TT2's now :o
ABA383
10-01-2005, 08:20 PM
255 50 R16 M/T ET Radials are the ticket if you want to use some 16x8 stockers...I've got a pair and run consistent 1.6s to 60' with 16x8s all around and both sway bars in place. These things hook! They ride nice, and they run $159/each locally...If I switched to front skinnies and removed the front bar I'm confident I'd hit a 1.59...I was a BFG fan for a loooong time, but no more....
--Alan
