88 irocz 350 5-spd
09-30-2005, 12:49 AM
hi, i have a 88 camaro 350 tpi and was wondering if anyone knew about a good intake swap. would an lt1 or ls1 intake fit, and if it did would i get any extra horsepower or not?
LT1/LS1 Intake88 irocz 350 5-spd 09-30-2005, 12:49 AM hi, i have a 88 camaro 350 tpi and was wondering if anyone knew about a good intake swap. would an lt1 or ls1 intake fit, and if it did would i get any extra horsepower or not? 2000GTP 09-30-2005, 04:30 AM My buddy did the Stealth Ram intake swap, it is a little pricey though in my opinion. I dont know how the gains compare to that of an LT-1 intake swap. Keep in mind some fabrication is in order to make an LT-1 work because your TPI has the top-mounted distributor where the LT-1's is mounted by the crank pulley in front. I dont think an LS-1 will work at all, they have a different style of heads, but I may be wrong, but I havent heard of this being done at least. Kwiksilverz28 09-30-2005, 06:32 AM LT1 can be made to work. LS1 is composite, does not have coolant passages, no distributor hole, and is completely dimensionally different. 91RSLT1 09-30-2005, 10:17 AM hi, i have a 88 camaro 350 tpi and was wondering if anyone knew about a good intake swap. would an lt1 or ls1 intake fit, and if it did would i get any extra horsepower or not? Check out LT1intake.com. I would go with the LT1 intake, good gains for a good price. | ||
