PCM Bad?
Husker_9495
09-28-2005, 11:35 AM
How do you check to see if the PCM is good. I'm told it is bad. I have a hypertech programmer (which the pcm responds to) , no scantool or software. Should i use something like lt1 edit or a scantool?
turbo_Z
09-28-2005, 01:31 PM
If the car runs then the PCM should be fine.
Husker_9495
09-28-2005, 06:51 PM
Can you tell me about failed emission NOx. Cat is new, EGR is functioning.
Don't know where to turn...... :confused:
infinitebird
09-28-2005, 10:46 PM
Did you let it warm up enough before the test?
Are there any other known issues with it? Does it run well?
