Single to dual radiator?
YARDofSTUF
09-28-2005, 05:41 AM
So I saw a lower dual fan radiator bracket, do I need anything else to switch in the dual fan?
And how would I wire it up?
masiroc566
09-30-2005, 03:45 PM
You will also need the upper bracket....as far as the wiring goes...If you can read wiring schematics a good book is Chilton...pg. 6-58 has a 1990 5.7L tuned port wiring schematic. You will also need the wiring connections...prpbably the best bet would to find it at a junk yard...just the wiring going to the fans....Good Luck!!
masiroc566
09-30-2005, 04:43 PM
Do you have the fans already? I have the 2 and the wires if you are interested....let me know if you are....
YARDofSTUF
09-30-2005, 10:19 PM
Think I've got the fans already, can take em off a friends totaled car.
masiroc566
10-02-2005, 01:58 AM
Will you be using A/C too?
