Alignment Questions
YARDofSTUF
09-27-2005, 08:16 PM
When getting an alignment done does that just straighten up the wheels, or can that move them forwad a bit?
After putting new wheels and tires on my car I knew the alignment was off, its very easy to see. But it looks like the passenger side wheel is more pushed back or closer to the wheel well.
autoxr
09-28-2005, 06:54 AM
That would be your caster. The caster is what moves the wheel forward or backward in the wheelwell. And yes, it can, and should be corrected.
YARDofSTUF
09-28-2005, 07:59 AM
Is that done in alignments or do i need to request that, Good to hear, I was worried somethign was bent!
thanks.
autoxr
09-28-2005, 09:12 AM
Yes, that's part of an alignment. Camber, caster, and toe is what they will check and correct if it's out of factory spec.
YARDofSTUF
09-28-2005, 08:01 PM
thanks.
