Lean hesitation on '95 LT1 turbo
engineermike
09-27-2005, 08:16 PM
I've been trying to fix this for some time now. When I tip in the throttle abruptly, the engine consistently stumbles, even backfires. The wideband shows a spike up to ~18/1 A/F ratio instantaneously. I have 84 lb/hr low impedence injectors and the Acceleronics impedence converter. The car runs fine otherwise. Any ideas?
Mike
Alvin@pcmforless.com
09-27-2005, 08:33 PM
have you tried tuning in the VE tables in those areas? Prehaps add more fuel in the higher KPA regions where your experencing the tip in problem
