Traction Control relocation Kit
Old Sep 26, 2005 | 06:09 PM
Coop1's Avatar
Was wondering if someone makes a Traction Control relocation kit so I can mount a ATI procharger on my 97Z. Any help will be greatly appreciated.
Old Sep 26, 2005 | 06:29 PM
Mu2LoW's Avatar
Re: Traction Control relocation Kit
Not sure about the ATI kit - but Greg @ blowerworks has the relocation kit for the Vortech - should be the same.
http://www.carrollsupercharging.com/
Old Sep 26, 2005 | 08:37 PM
wingnut's Avatar
Just dump the TCU.
Wingnut
Old Sep 28, 2005 | 05:53 PM
blitzer454's Avatar
I used such a kit, when I get home from work I will try to find the contact info from where I got it.
But, frankly I wouldn't waste my money on it. The kit consisted of two brake lines, some wire to extend the wiring harness and a two page, bad photo copy, instruction sheet. The new location for the TCM is just right of the radiator sitting on the frame. You have to move the wiring harness that runs on the frame around a bit to make the TCM fit. Then the idea is to use the the supplied brake line from the kit to connect the lines between the ABS unit to the TCU, but I found that the bends were not in the right location and ended up buying new brake lines and bending them myself. If I remember right I paid around $200 for the kit and only used the instructions and wire and the instructions sucked. The hardest part was making the double flare fittings after you cut the brake lines and getting the TCM mounted to the frame. The damn wiring harness is not as easy to move as you may think.
Old Sep 28, 2005 | 10:04 PM
blitzer454's Avatar
I got mine from www.db-performance-eng.com although you won't find it on their website, you will need to contact them directly.
Rod Bender
Nov 7, 2023 02:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
